Thread: pdf link test
    Jun 2008
    Default pdf link test
    Can some of you test this link for me please? Open the pdf and try the link. It's not working on my computer. I'm trying to see if it's a problem with my pdf converter or my machine. When its in Word, it works but when I convert it to pdf, it doesn't work for me.
    Anyway, if you got a few seconds, open the pdf and let me know if the link in it works or not.
    Thanks.....
    Attached Files Attached Files
    Default Re: pdf link test
    John,
    It worked for me. Took me to your website.
    rick
    Jun 2008
    Thanks Rick. Must be a setting on my putor that prevents it for me.
    Bert de Haan's Avatar
    Bert de Haan Guest
    Didn't work for me. Looked like it would; a dialogue box came up giving me the option to allow or to block. I allowed but then nothing happened.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Quote Originally Posted by Bert de Haan View Post
    Same steps for me, but selecting 'allow' did work and took me to the site.
    Jun 2008
    I discovered something. If I open a blank IE window the link will work. If I try to do it with the only the Inspection News page up it won't. If I close all windows and try it from the pdf document stored on my drive, it opens IE and navigated to the link.
    Not sure but would this suggest an IE issue on my end? Odd kinda problem. I'm not worried about it for my use but I want my clients to be able to use the links in the PDF's I send out.
    Bert de Haan Guest
    I use Firefox but if I have an IE window open as well, the link works. ??
    Mitchell Toelle's Avatar
    Mitchell Toelle Guest
    Smile Re: pdf link test
    I use IE8 Jpohn and yhe link worked for me as expected...similar to the other responses...and took me to your site. Nice way to get hits. Very cleaver!!!!
    Wink Re: pdf link test
    Worked for me John, although you may want to hire a professional model for the mug shot.
    Update
    I have PDF Converter on one of my computers and when the PDF is opened I cannot click on the link at all.
    Just some info
    Jun 2008
    Quote Originally Posted by Mike Picarello View Post
    hahaha...no soup for you!!!
    BTW, that rental insp I did the other day did have the ADT smoke alarms but they were not hardwired. The client was not happy when I told them it didn't comply with Balt County.
    Thanks again Mike for helping with my questions now and then. See you at the next meeting.
