		Thread: Top of siding casement trim
	07-14-2007, 04:55 PM #1 Top of siding casement trim Top of siding casement trimLast edited by Jeff Eastman; 12-20-2007 at 08:24 AM.
	07-14-2007, 07:37 PM #2 Re: Top of siding casement trim Re: Top of siding casement trimYou are right that "projecting wood trim" (code language) should have a continuous cap flashing installed above it.
 Still, what you show in the picture is a pretty well sheltered piece from above and "looks" like it might even be a fiber cement product and not wood.
 My guess is that you will have found bigger fish to fry at that house and that you would not be doing yourself or your client harm by just moving on to the bigger things.
	07-14-2007, 07:51 PM #3 Re: Top of siding casement trim Re: Top of siding casement trimPut it in the report but not in the summary.
	07-15-2007, 03:21 AM #4 Re: Top of siding casement trim Re: Top of siding casement trim
 This if off topic for the thread but I am totally against summaries for an inspection report. I NEVER provide a summary to my report. I always try to write a concise and uncluttered report but my objectrive for my target audience is never taylored toward the laziest reader.
 In my opinion the entire report is pertinent, should be of substance, and should be read word for word by the buyer who is potentially about the make the largest expenditure of their life.
 Cheat sheets, cliff notes, or a quickie summary should not enter into this equation during the critical decision making process by the buyer!
 Yes I realize that many real estate agents out of shear laziness like to see short, quick, and abbreviated reports before they cash that commission check. I am just not into providing it for them. The buyer (who ultimately writes my paycheck) has to live with their decision thereafter and deserves better than an abrieviated report.
	07-15-2007, 05:02 AM #5 to summary or not to summary to summary or not to summaryHere in PA the law says the inspection to find "material defects", so at the end of the report I list and summarize what I consider to be the material defects, but I also indicate that this is somewhat subjective, that the client's priorities may differ, and that, of course, the client should read the entire report. I don't have a problem with separating out the life-threatening furnace from the tub drain control that isn't working.
	07-15-2007, 07:57 AM #6 Re: Top of siding casement trim Re: Top of siding casement trimI agree with you Phillip, no summary for me. But then I go back to the day before computer generated reports when I wrote everything out on a 4-part carbonless form and my report was shorter than most peoples summaries today. I still try to be concise without a lot of clutter, but the longer I do this, the longer my reports have gotten!
	07-15-2007, 08:10 AM #7 Re: Top of siding casement trim Re: Top of siding casement trimJim wrote: "I agree with you Phillip, no summary for me."
 Same here.
 RR
	07-15-2007, 08:16 AM #8 Re: Top of siding casement trim Re: Top of siding casement trim
