Results 1 to 2 of 2
    dan orourke's Avatar
    dan orourke Guest
    Default Water supply lines in attic
    Default Re: Water supply lines in attic
    Quote Originally Posted by dan orourke View Post
    Is it a requirement for water heaters' water supply lines to be insulated?
    Oklahoma City is shown as having a 13 degree design winter temperature degree day, which is less than 32 degrees.
    Being as those lines are outside the thermal insulated envelope, yes, insulation (or heat - or both) is required.
