Results 1 to 2 of 2
    Ian Currie's Avatar
    Ian Currie Guest
    Default When were weep screeds, two layers of felt, etc first recommended for stucco homes?
    After speaking with a number of local stucco installers, I've discovered that stucco clad homes in Winnipeg are, to this day, built without weep screeds, stucco accessories, kick-out flashing, and with only one layer of paper / wrap.
    I'm curious to know when (what year) these preventative measures became commonplace in your area.
    Jul 2007
    Phoenix, AZ
    Default Re: When were weep screeds, two layers of felt, etc first recommended for stucco home
    First printing of ASTM C 841-76, Standard Specification for Interior Lathing & furring -1976
    Adoption by California Lath & Plaster Asso-1981
    ASTM C 842 (Revision of 841) published in 1982
    ASTM C 926 Application of Portland Cement Based Plaster-1981 approx.
    As far as I can tell, a base screed was always in the standard, but there were several styles available, so it was just a steel thickness callout.
    You will need to get documentation of when, or if, these were adopted in Canada. Sometimes they go their own way...
    Last edited by John Carroll; 09-07-2010 at 09:33 PM. Reason: added sarcastic comment for HG.
