Results 1 to 16 of 16
    Thomas Thayer's Avatar
    Thomas Thayer Guest
    Default Black liquid substance behind water fixture??
    Hi all! I'm looking for some help identifying this black liquid coming from behind water fixtures? I've only seen it once before. See attached picture.Thoughts? Recommendations?
    Thanks in advance!
    Default Re: Black liquid substance behind water fixture??
    My Though http://www.permatex.com/products/Aut..._Sealant_a.htm
    Old School Auto Mechanic used Permatex on The treads.
    Oklahoma City
    Could be some type of insect bait such as roach bait etc.
    If it weren't for lawyers, we would never need them.
    I will guess a leaky sewer line...
    I agree with Frank. Its looks like some of the roach bait gel we used to use.
    rick
    Leaky sewer lines don't run uphill on a wall as such.
    That's where it started...and ran downhill. I've seen oakum joints leak that type of oily substance. Nice try though.
    I hope not on a supply line!
    My bet is on bug bait.
    I'm thinking some John Carpenter horror film where the walls start bleeding.
    David Bell's Avatar
    David Bell Guest
    Being that the stain is also on the escutcheon I would guess that something stored under the sink leaked.
    Clearly, it's a pest control gel applied to the wall penetrations. Very common in this area. The "goo" is applied via a syringe around any pipe, penetration, or opening.
    I have never seen a bug man make a mess like that. They should be ashamed of themselves for being so unprofessional if that is what is shown in the picture.
    Did it taste like bug gel, or pipe dope?
    Here is the gel I mentioned.
    Jul 2010
    Northern, Ca.
    Maybe it was the home owner that made the mess
    Ron Bibler's Avatar
    Ron Bibler Guest
    If its on the Hot water side as it looks like it is you can get fumes from the heat. and should be noted in your report.
    Any time I see any petroleum or other type materials applied I call it out...
    Had a contractor put Copper green on some hot water pipes when he was treat some adjacent framing and the fumes from the stuff got the lady of the house sick. Bad news for him... that was like 30 years ago and I never forgot that...
    Best
    Ron
