    Default Odd ejector plumbing
    "Ejector" pump. Lid is attached to floor in manner I could not determine, and I could not remove it to determine if anything (DWV or foundation drain) is draining into the sump below the lid, but there is nothing but a laundry in this basement (AC condensate drain enters pump lid neat corner of room).
    But... what's up with this "loop" arrangement - makes no sense to me....
    Default Re: Odd ejector plumbing
    WHY? or is that a Polish joke?
    Not sure about this pump in particular, but sewage ejector pumps are supposed to discharge into the waste line from the top - maybe that's why it's plumbed this way?
    But - that doesn't really look like a sewage pump anyway - the lid doesn't looked sealed. Are there openings in the lid? Do you know what drains into it in that copper pipe? It looks more like a sump pump.
    James Duffin's Avatar
    James Duffin Guest
    Looks good to me except the line from the pump needs a check valve and a ball valve installed.
    The discharge side of that is to the right (at least, that's the side with the check valve).
    Oh, it's sealed down real good, and I could not determine how. The lid is home-made and there didn't seem to be any fasteners - I suspect it's caulked down to the floor with adhesive caulk. Attic access was sealed up tight too - got an OK from the sellers to try to open it - worked on it for quite a while with the Stanley knife, but finally gave up when the plywood hatch cover started to delaminate before I could break it loose. Hopefully the sellers will get it off, and I'll be back there for a second look.
    This was a Flip O' Rama, and there are a number of such home-brews (I thought the 25' garden-hose drain line from the island dishwahser to the laundery tub in the basement was pretty slick, myself)... lots of (I suspect) unpermited work - and I recommended the clients check with the building department.
    Realtor was there when I gave the clients my "you could be on the hook for unpermited work by former owners" speech.
    Afterwards, when the clients we driving off we talked a bit about the inspection.
    Realtor said:
    "While I was driving down I was taking to the listing broker, and she asked how it thought the inspection would go. I told here that I didn't have a particular reason, but the 'vibe' I got from this house was 'Unpermited Rehab by Son-In-Law'".
