Results 1 to 3 of 3
    Gene Koshiol's Avatar
    Gene Koshiol Guest
    Question PV panels over roof vents
    Has anyone encountered Solar PV panels being installed over roof vents, plumbing vents, B-vents, exhaust vents. What criteria is being followed, what code sections pertain? Items of concern are the corrosiveness of Hydrogen Sulfide from sewer gases to the panel and electrical components, moisture from exhaust vents etc..
    Philip's Avatar
    Philip Guest
    Default Re: PV panels over roof vents
    Quote Originally Posted by Gene Koshiol View Post
    If you cover up vents then they are no longer venting. This is a no brainer.
    Besides the obvious that Phillip mentioned. Check out the NRCA website. They have some docs on PV roof installation
