    Jul 2010
    NC
    Default Carlon flex plus
    Hello,
    Wondering if Carlon flex blue plus E73317 is suitable for untraviolet light (exterior use). I had read somewhere that not all carlon flex blue is rated for ultraviolet light. Any help will be appreciated.
    Sid
    Default Re: Carlon flex plus
    The following clickable links will take you to their listing information at the UL website. The pages themselves also contain clickable links for the smurf.
    FKHU.GuideInfo - Electrical Nonmetallic Tubing
    The individual listing: FKHU.E73317 - Electrical Nonmetallic Tubing
    and The introduction or scope for the UL standard: Scope for UL 1653
    Ambient temp limit 122 F, easily exceeded in direct sunlight. Most attics are enclosed, should not be in direct sunlight even from attic window.
    Jul 2010
    NC
    Thank you H.G.
    To my knowledge NONE of those "smurf" tube types are rated for use outdoors. There is an exception to the Uses Not Permitted in the NEC "(9) Where exposed to the direct rays of the sun, unless identified as sunlight resistant", but I doubt you will find any which is sunlight resistant.
    http://www.carlon.com/Master%20Catalog/ENT_2B43.pdf
    Also see page 15, "Approved Uses" in the above.
    You are most welcome Sidney.
