    Jonathan Cartwright's Avatar
    Jonathan Cartwright Guest
    Talking Broiler settings for ceiling heat
    When checking electric ceiling heaters in the bathroom do you always check the broiler function?
    Do you wait until the bathroom reaches the desired temperature, such as 375, or do you just note that the unit turns on?
    Have a great weekend.
    Jonathan
    Default Re: Broiler settings for ceiling heat
    I put a swordfish steak about 4 inches away for 2-3 minutes, then turn it over for another couple minutes. If it's not delicious, I write up the heater.
    Very funny. I guess they had that left over from the old stove.
