Thread: Cut valley
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Cut valley
    Often times it is difficult to explain incorrect installation of a cut valley. What verbage do you use so your client can grasp what you are tring to explain.
    Glen Neal's Avatar
    Glen Neal Guest
    Default Re: Cut valley
    I am new to the forum and I realize this is an older post. Do my eyes deceive me or does it appear as though the low volume roof is ran over the high volume roof in the photo?
    I am under the impression that the low volume roof should run under the high volume by a t least 12"
    chris mcintyre's Avatar
    chris mcintyre Guest
    Quote Originally Posted by Glen Neal View Post
    I am new to the forum.....
    Welcome Glen....and you are correct.
    Ted Williams's Avatar
    Ted Williams Guest
    Apparently roofers like cut valleys.
    Valley Techniques
    Cut valley is easier and faster than a woven one. Time is money, they say.
    Frank Suchodolski's Avatar
    Frank Suchodolski Guest
    Metal valleys are better if we are comparing and install is quicker but roofer has to fork out the extra $ for the metal valley. Laminated shingles also have a habit of failing when you bend them into the valley.
    Frank Suchodolski, RRO, TQ
    High Profile Roof Care
    Holladay, UT
    Mathew, I recently added this to my reports.
    It appears that the roof valley is improperly installed. This may lead to roof leaks and water penetration into building components. A qualified roofing contractor should evaluate and repair/replace as necessary. View the video at following link for proper installation of roof valleys: Video Library - How to do Valleys
    http://acloserlookslc.com/
