Thread: Gray PVC
09-23-2010, 06:34 PM #1
Gray PVC
I don't think I have seen this before. It is actually labeled PVC, with an ASTM D2665, just like the white PVC it is connected to. Was this a product that was in use a while ago? This addition was pretty old. I think it was put up in 1976-1978.
Similar Threads:Jim Robinson
09-24-2010, 04:27 AM #2
Re: Gray PVC
Most of the grey pvc I have seen is schedule 80. It has a higher UV rating and can handle higher tempuratures.
09-24-2010, 05:48 AM #3
Re: Gray PVC
09-24-2010, 07:27 AM #4
Re: Gray PVC
Thanks. They must have been cleaning out the truck. They had white PVC, gray PVC and ABS all patched in on the drain lines. I couldn't read if it was schedule 80 or not, but that would make sense.
09-24-2010, 07:38 AM #5
Re: Gray PVC
Love the tape!
What holds the joints together?
09-24-2010, 11:14 AM #6
Re: Gray PVC
The tape was on the insulation around the supply lines for the bath..
09-24-2010, 11:51 AM #7
Re: Gray PVC
Is that a leak bottom left?
09-24-2010, 06:14 PM #8
Re: Gray PVC
Wood top right looks wet also.
09-24-2010, 10:15 PM #9
Re: Gray PVC
The colors have no real meaning industry wide, some gray PVC may be schedule 80 but the ASTM posted is schedule 40. Some early versions of PVC were colored "industrial gray" not to be confused with actual industrial grade.
www.BAKingHomeInspections.com
