    Jon mackay's Avatar
    Jon mackay Guest
    Default Gap at siding transition
    What type of trim should be at this gap between the old aluminum siding and wood siding above the trim board?
    Do they make a type of J channel or similar?
    Default Re: Gap at siding transition
    It looks like "Z" trim could work.
    Montreal, Quebec
    I agree with James; the piece would most likely have to be custom made to fit correctly and be installed before the metal siding is put on.
    Ron Bibler's Avatar
    Ron Bibler Guest
    I agree with James and Jon...
    Best
    Ron Bibler
    Santa Rosa Pest Control - Inspection and Pest Control in Sonoma County
    It looks like it would be a perfect install if the Z-metal flashing were there. The problem is usually in the other direction... getting the installer to leave the gap at the lower edge of the siding rather than just installing it tight.
    Jon mackay's Avatar
    Jon mackay Guest
    Thank you everyone..
