    mike huntzinger's Avatar
    mike huntzinger Guest
    Default water heater failure
    found this inside the burner of a 16 year old wh. i think it is the flue pipe difusser
    Default Re: water heater failure
    "found this inside the burner of a 16 year old wh. i think it is the flue pipe difusser"
    Yes, that looks like it.
    Quote Originally Posted by mike huntzinger View Post
    More common name is "baffle".
    Cool Re: water heater failure
    turbulator by some mfrs. Otherwise, flue baffle very common. These usually have 'wings' at the top so they are suspended. Not a good sign but this WH needs to either be replaced or at least really gone over by a pro.
