    Kevin Luce's Avatar
    Kevin Luce Guest
    Thumbs down Taking off the advertising when posting
    For some reason, I do not like advertising for something I do not like just because I type in a word in my post. Is there a way I can prevent this from happening? Example: report
    Default Re: Taking off the advertising when posting
    Test
    report
    Didn't see an add with firefox w/ the adblock plus extension installed...
    Tim Moreira's Avatar
    Tim Moreira Guest
    Brian,
    In my opinion, as I read through the posts, the advertisement banners in between posts gets a little annoying.
    Also, on the old board when posting you were able to scroll down and reread what the other folks had posted. Is that possible to do here? It is helpful when answering long posts with multiple questions.
    Not picking, just my two cents.
    Capistrano Beach, CA
    Quote Originally Posted by Kevin Luce View Post
    Hi Kevin, Thank you for your input. I will keep that in mind and with some more work/programming I may be able to set this up as an option.
    Yes, just scroll down
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Tim Moreira Guest
    Red face Re: Taking off the advertising when posting
    Sometimes I can't see the forest for the trees.
