    Andy Jarchow's Avatar
    Andy Jarchow Guest
    Default two way switch question switch wont work unless the other is in a certain position?
    Hello all,
    While inspecting a home yesterday I was trying to figure out what function each wall switch has. Two switches I found operated the garage lights. One switch was in the garage and the other in the house. One of the switches would not work unless the other was in a certain position.
    Does this mean it is the wrong type of switch ie. 2way, 3way…? Or is this normal?
    Thank you
    mk
    Default Re: two way switch question switch wont work unless the other is in a certain positio
    It means that one of the two switches is wired incorrectly.
    Yes, wired wrong, one option. Most likely & typical cause. The older switches do not look like the newer ones, ie. 1945 /1990. So people have a problem replacing them correctly.
    Bad switch is also possible.
    The actual wire usual not the problem.
    Be careful reporting the repair process since this could very well involve an incorrect cable that would require running a new cable or wire. Two switches for one device needs two 3-way switches with two traveler wires between switches. Some older homes were wired wrong or someone tried to install 3-ways and failed to run the correct wire.
    www.BAKingHomeInspections.com
    I most often find this where a dimmer has been installed. Always check operation in all combinations of switch settings.
    Quote Originally Posted by Mike Krueger View Post
    Hello all,
    Thank you
    mk
    Multiple location switching involves three-way switches, one at each end of the control path, if more locations within the run of the travelers, four way switches are installed in between the beginning and ending 3-way swtiches. (No "2-way" switches). 3-way and 4-way switches are not indicating (do not say "on/off").
    Generally, the symptoms you describe are usually attributed to either a wiring error, or having installed an incorrect switch (3-way and 4-way switches look similar - difference is an additional screw post).
    However, it may be that this is not a 3-way switch loop at all, it may be that there are two single throw switches in series - this is allowed, but can be confusing.
    If the garage is not attached, and is not otherwise electrified, except via the garage switch: it may be that the switch local to the garage is acting as the disconnect for the structure.
    Several possibilities, including but not limited to:
    - bad switch
    - broken conductor (broken for various reasons, even a nail)
    - wired wrong
    - one switch is a single pole switch and not a 3-way switch
    - etc.
    Andy Jarchow Guest
    Very helpful!
    Thank you all
    Have a great week
    mk
    Jul 2007
    Must be in series.
