    dan orourke's Avatar
    dan orourke Guest
    Default Re: Electrical cable inside of chimney chase
    How would you have proper fire blocking if the chase has a cable running through it? I'm going to say that it is a No, No.
    After I think about it for a moment, I guess you could have an outlet or line for the fireplace to power a blower. But it would not be running down the chase.
    Just keep the NM cable away from the chimney vent.
    If the cable runs through a firestop, seal around it just like you do when a cable runs through a top plate (fireblock).
    Smile Re: Electrical cable inside of chimney chase
    The rest of the chase is ordinary construction. As long as the cable is stapled and fireblocked, I see no problems. Done all the time.
    bob
