Thread: Minimum slope requirements
11-08-2010, 10:25 AM #1
Hi, need quick answer. what is min. slope requirement for spanish tile installation.
Mike Richards
11-08-2010, 11:14 AM #2
Re: Minimum slope requirements
If you can't identify the manufacturer and check their requirements:
"(For clay tile roofs) NRCA recommends a minimum of one layer of No. 30 asphalt-saturated felt applied horizontally in shingle fashion on roof decks having a slope of 10:12 (40 degrees) or more. For roof decks having slopes of 4:12 (18 degrees) up to 10:12 (40 degrees), a minimum of two layers of No. 30 asphalt-saturated underlayment should be applied horizontally in shingle fashion. NRCA does not recommend installing tile roof systems on roof slopes less than 4:12 (18 degrees)." (Underline mine).
- Clay tile and concrete tile | NRCA National Roofing Contractors Association
11-08-2010, 12:18 PM #3
Thanks youv'e been a great help
