Thread: Double height beams
11-11-2010, 08:46 AM #1
Double height beams
I inspected a house which had cracks and binding doors in the middle area. Underneath the beams are made from double-height 2x10's, tied together by 2x4's. Now the Realtor is in orbit because they've had 2 previous home inspections (I guess when it was purchased, and I know they have a pre-inspection they did when they listed it in August) which showed no problems either with the 5 (!) doors which now bind or do not close at all or question the beams. Fun and games. . .
11-11-2010, 07:29 PM #2
Re: Double height beams
I doubt anyone has any data or proof as to the exact day that the sagging caused enough issues to be readily visible so the only blame that could be placed on a previous inspector is for not knowing that the stacked 2x10's are not adequate. How bad depends on loads, spans and wood species. Most SOP's will protect (on paper) the inspectors who do not know about correct framing practices and recognizing structural shortcuts as long as no substantial symptom was missed.
The agents have now found a good inspector but whether or not they really want one is another topic altogether.
www.BAKingHomeInspections.com
11-12-2010, 06:13 AM #3
Beam itself shouldn't be sitting on a 2x4 The 2x4 can be crushed from the weight. Stacked 2x10's not very strong Just plain bad design/ build
11-12-2010, 07:44 AM #4
11-12-2010, 06:11 PM #5
11-13-2010, 07:48 AM #6
I believe he was referring to the one on top of the block post in the center photo. I included that one because there was apparently enough pressure on the supports to "squirt" the shim back out of the stack. (There did not appear to ever have had a second one to level the surfaces.) You're right, it would have the potential to crush the 2x4 also. In this case, that probably won't happen, as the house is 21 years old. However, whoever said it was "bad design/build" pretty well nailed it. I suspect the "build" half of that; I cannot imagine a set of design drawings going out with that on them! In fact, ever since the inspection I've been racking my brain trying to imagine what the drawings actually might have shown that they figured would be so much cheaper to do with so many 2x10's. Maybe a 6x18 or so glue-lam. . .
11-14-2010, 07:53 PM #7
Hi, ALL &
Any idea what those cinder blocks are supported by (if anything at all) ???
CHEERS !
-Glenn Duxbury, CHI
11-15-2010, 10:08 AM #8
We don't do a lot of post and beam raised foundations anymore here in CA ... have gone almost entirely to slab on grade ... but I wonder if what you are looking at is someone's attempt to bring up the bearing surface of the piers instead of actually trying to increase load bearing.
I would bet the design called for doubled 2x10's and these are suppose to be side by side sitting on short 4x posts between pier and beam. Without any experience in the technique, a DIY could think "hey, there is just enough room for the second 2x under the first ...." when there should be a post. Plans also probably spec the double 2x to be spiked together, hence the extra 2x4 scabs to hold things together.
The "bad build" hits right on this one.
As for the pier, we see these set on bare ground in homes built around here in the 1950 - 1970 time frame. Not till the 1970's that they started increasing the bearing above bare soil ... and we do a lot of shim work to "fix" interior door issues on the older homes.
Ed
11-15-2010, 11:55 AM #9
I'd also note the possibility of rotation of the "stacked" beam assembly with at least one unrestrained end.
11-15-2010, 04:06 PM #10
Hi Linda the other questions comes to mind is when was the last time someone played with those beams? and was there anything changed since aug in the house to make things shift like heavy items being moved like say a piano? from one local to another. also does the house have a history of these things happening. were there any reno's done? and the most important question is what can be done to fix it right?
11-15-2010, 05:07 PM #11
to me it looks like someone tried to fix a sagging floor by jacking and putting a beam under the sag....which caused the doors to bind....
