Results 1 to 13 of 13
Thread: Rusted lug
    Jul 2010
    Northern, Ca.
    Default Rusted lug
    Inspected the main service panel on a home today. It all look good (20 yrs. old) except the rusty lug I found at the connection for the heating and air system, this was the only rusted lug in the panel. By the way the unit it self is brand new. Does anybody know what might be going on? Sorry if there is a lack of information and no pics. Thanks
    Default Re: Rusted lug
    I would suspect heating at the connection.
    LEO304E CARR's Avatar
    LEO304E CARR Guest
    Quote Originally Posted by David Garton View Post
    I would say that your looking at a circuit breaker with one rusty lug.
    Is the lug tite?
    Allso is the service fed with ser cable? As time goes by some times water travels in along the wire Right into the panel.
    Jul 2010
    Northern, Ca.
    Quote Originally Posted by LEO304E CARR View Post
    Is the lug tite?
    Thanks Jim
    Not sure if it was tight and yes it is feed with ser. cable
    LEO304E CARR Guest
    Thanks Jim
    Check to see if the duct seal is dryed out and cracked that will let water in.
    If the lug is loose that will cause arckhing and over heating .
    Jul 2010
    Northern, Ca.
    Is the lug tite?
    Electrician look at it today, lug is rusted tight, it was a moisture problem
    Thanks for the follow-up post, David. Anything suspicious in the electrical panel warrants a closer look.
    LEO304E CARR Guest
    Did he find that water was traveling along the ser cable?
    David Cortez's Avatar
    David Cortez Guest
    Not trying to be a smart-ass, but isn't rust always a moisture problem? As I recall, it's the product of two disimilar metals that come in contact with moisture.
    Jul 2010
    Northern, Ca.
    Quote Originally Posted by David Cortez View Post
    Smart-a..
    The metals do not even need to be dissimilar for rust to occur. The metals simply need iron content and some humidity (versus what most think of as "moisture") to cause the iron to turn into iron oxide ("rust").
    When you have dissimilar metals, you have galvanic action and that creates "corrosion", not rusting (at least to my knowledge, I may well be scientifically correcting as soon as I click the 'Submit' button ).
    Jul 2010
    Northern, Ca.
    Thanks Jerry for clarifying that for David C.
    Lloyd Miller's Avatar
    Lloyd Miller Guest
    To find only one rusty lug usually means it was overheated (if no water present or tracked to that spot). I remember seeing a CB with one lug with a cherry colored lug (yes it was loaded).....the problem was that the lug "appeared" to be tight but because it was cross threaded it made one think is was seated properly (it was not).
    Just my 2 c
