Thread: Double Tap At Main Lug
11-23-2010, 07:19 PM #1
Looked in a ITE panel today and found a double tap @ the main lug, but other end went to a ITE Safety Switch box. Would this be acceptable
11-23-2010, 07:40 PM #2
Re: Double Tap At Main Lug
No, that lug is good for only one conductor.
11-23-2010, 07:53 PM #3
Don't forget all those neutrals and grounds in the same terminals with each - that is not allowed either.
11-23-2010, 09:58 PM #4
To add
Appears there is no identified neutral ( not a big deal but just pointing it out)
You probably mentioned it in your report but they could use a few lessons on properly fastening those nm cables in the photo of the safety switch.
11-24-2010, 12:04 AM #5
11-24-2010, 03:48 AM #6
