    Jim McClendon's Avatar
    Jim McClendon Guest
    Question Asbestos roof shingles
    What do asbestos roof shingles look like? Are there different types? Are they still made?
    Wm. Kibbel's Avatar
    Wm. Kibbel Guest
    Default Re: Asbestos roof shingles
    Jim McClendon Guest
    Thanks for the link WK.
    Asbestos single identification chart:
    Asbestos Shingle Identification Photos, Also known as Transite Roof Tiles
    Here in Chicago I see this pattern occasionally, you have to check all sides of all roofs, for example you may find it’s been left on garages when the main structure has been re-roofed:
    TinyURL.com - shorten that long URL into a Tiny URL
    http://www.customtileroofing.com/images2/Asbestos_Transite_Tiles/BELGIUM%20ETERNIT%20FIELD%20SLATE%20AND%20RIDGE.jp g
    One red flag to check further are shingles that overlap one other on one side:
    http://www.jenkinsslate.com/images/sidelapasbestos.jpg
    I’ve also seen this type of Transite roofing, usually on shed roofs:
    http://www.printedpages.net/images/3...mpany-1947.jpg
    http://www.asbestosnews.com/images/roof.jpg
    And this type, which mimics slate:
    http://www.customtileroofing.com/ima...UTCH%20LAP.jpg
    And also faux wood:
    http://www.printedpages.net/images/7...age_1-1955.jpg
    http://www.customtileroofing.com/ima...20American.jpg
    The bottom line is that asbestos can look,
    superficially
    at least, like just about any other kind of shingle roofing.
    Ron Gries's Avatar
    Ron Gries Guest
    Here is one home that I found in Roswell, NM with asbestos shingles.
    David Banks's Avatar
    David Banks Guest
    Maybe the Aliens brought them with them?
