Results 1 to 2 of 2
    dan orourke's Avatar
    dan orourke Guest
    Default Plumbing routing in crawlspace
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Default Re: Plumbing routing in crawlspace
    That was what is called thumb gum. It is usually used where a/c lines go into the house. It is probably used for expansion and contraction of the pipe. That copper is soft copper and not sure it is k-copper which it should be.
