Thread: Water Heater
    Larry Hood's Avatar
    Larry Hood Guest
    Default Water Heater
    I have a water heater that I am trying to find the age for replacement.Can someone help me out Its a American Water Heater Model E62-30L-0450,S/N 1023T404897,Product # 9250272004.Does any of the numbers tell me a date. I believe State is also AO Smith.Any ideas would be appreciated.
    Default Re: Water Heater
    I think I got this from someone who posted it here.
    Larry Hood's Avatar
    Larry Hood Guest
    Gunnar,
    Thanks for the info,downloaded and in my reference book.Larry
    Utah
    Great material, thanks Gunnar.
    Daniel Mummey's Avatar
    Daniel Mummey Guest
    American Water Heater Company, manufacturer of 52 separate brands of water heaters, uses a 10-digit serial number with a year/week code in the first four digits of the serial number. The year of is the first two digits followed by the two digit week of the year. For example,the serial number 0602****** indicates that the water heater was manufactured the second week of 2006.
    Andrew Christel's Avatar
    Andrew Christel Guest
    Thumbs up Re: Water Heater
    Good Information.
    Thank you Gunnar.
    Thank you Daniel.
    Andy's Eagle Eye Home Inspections LLC - Home
    Nov 2007
    Chicago
    If you do not have a computer or a printed version of the PDF handy, just call the manufacture and give them the information and they will be more than happy to tell you the manufacturer date. And they will tell you if the heater that is there was a warranty replacement and how long the remainder of the warranty is left.
    I have had a job where the heater manufacture date was only 18 months old, but when I called the manufacture I was informed that the heater was put in as a warranty replacement on a water heater that was 5 years 11 months old, so the warranty was done one month after the installation.
