http://www.oahi.com/reading/SMMNoticeAgenda-Dec7-.pdf
http://www.oahi.com/reading/AppendixA.pdf
http://www.oahi.com/reading/AppendixB.pdf
http://www.oahi.com/reading/AppendixC.pdf
http://www.oahi.com/reading/AppendixD.pdf
http://www.oahi.com/reading/SMM-Dec72010-ProxyForms.pdf
Note the admission that OAHI recognizes that the designation RHI should be used for associates and applicants. It appears as I have said all along and contrary to the OAHI legal beagle that PR 158 was misapplied in the use of RHI which applies to 'anyone' in the Registry.
Disappointed to see that the proxy system for voting is still in use given the history of abuse by the BOD.
Also note the concept to achieve to TIPR and mandatory upgrading every 5 years.
Now the only question is will the apathetic membership turn out, use proxy A instead of using proxy B. Given the drastic membership renewal drop of 45% it appears OAHI had to appease the novices as an enticement vis-a-vie use of RHI.
