    Default What is the correct term for the circular holes in bricks?
    Default Re: What is the correct term for the circular holes in bricks?
    I'm going with "cores".
    I don't actually know anything, I just came up with this by doing a web search.
    "CORE. A hollow space within a concrete masonry unit formed by the face shells and webs. The holes in clay units. Also called a cell."
    Masonry Details
    Brick Terminology
    BRICK TERMINOLOGY Standard U.S. bricks are 2 1/4 by 3 3/4 by 8 inches nominal size. They may have three core holes or ten core holes.
    Thanks!
    Cool Re: What is the correct term for the circular holes in bricks?
    cores for hole and 'frog' for a depression in one face meant to key each brick in.
