Results 1 to 4 of 4
    Default Flex gas connector through cabinet wall
    Can't pass through a partition wall, how about a cabinet wall?
    (Also, comments on the general arrangement?)
    Default Re: Flex gas connector through cabinet wall
    I think the consensus the last time we went over this was that a cabinet wall was not a big deal unless feeding a slide in range where damage was likely.
    Well, throwing pots and pans in there ain't too bright. I'd recommend a simple removable panel be installed to protect the flex connector and that poppet style regulator. Personally, I would recommend that shutoff be replaced with a modern Z21.15 ballcock.
    Am I seeing things or is this flex line more than 3 ft. long? They could put a simple grommet where it penetrates the wall of the cabinet. What is in that space where the shutoff is?
    That's a corner cabinet.
    I would think it would have been better to hard pipe to the left through the cabinet wall and turn downwards there.
