    Default A book is a man's best friend
    And they say books are becoming obsolete!
    Default Re: A book is a man's best friend
    "evidence of corrosion and leaks noted on utility tub sink drain line - book wedged beneath drain line in meager attempt to circumvent proper installation noted as wrinkled from exposure to moisture - have serviced by a professional bookstore employee and all repairs made as needed"
    Aug 2009
    Michigan
    Wonder if that' a DIY plumbing book!
    Randy Gordon, construction
