Results 1 to 4 of 4
Thread: Ejector pump
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Ejector pump
    This is for a wet bar. Is a check valve required and does that coupling below the shut off function as a check or simple a coupling.
    Default Re: Ejector pump
    Not sure if a check valve is required but that rubber coupling/connector doesn't look like a check valve to me.
    Check valve could be intergral to the pump.
    state of jefferson
    a backwater or check valve required before the gate or ball valve.
