    Default Water heater vent pipe
    What do you guys think of this. I think its crap, I did not get any CO readings at start up but I still think it's crap. I would think the exhaust would have to blow directly out the barometric damper in the right weather conditions.
    May 2007
    Frankfort, KY
    Default Re: Water heater vent pipe
    The Tee needs to be reconfigured to a bullhead configuration.
    Check out this section from Field Controls site.
    FIELD CONTROLS, LLC - CONTRACTOR PRODUCTS DRAFT CONTROLS
    Definitely wrong Wayne. The combustion gases in that flue pipe are not going to make a 90 degree turn on their own away from that damper and up the chimney. Path of least resistance.
    David, Nice link, So I guess he had it right when he was at the truck but when he got to the unit it was 4:31 and Bud Wweiser was on the phone.
    Thanks NIck, That's what I thought too. I blamed it on the broker. HAHA
