    Jun 2010
    Las Vegas, NV
    Default InspectVue problems
    Does anyone have or know of someone that can convert the Version 5 library back to work in version 4 or another program that is comparable to InspectVue that I can switch to?
    Default Re: InspectVue problems
    I converted to version 5, but always kept my version 4 on the computer, since 5 never seemed to work right. I've been using 4 all the time.
    Paul Edmonson's Avatar
    Paul Edmonson Guest
    Peter do you have a backup copy of your IV 4 Library and do you sill have IV 4 installed on your computer? If so just restore the copy of the library. If not check out windows explorer on your hard drive to see if you still have IV 4 it should be under program data, IV 4 and check to see if you have master library file there. I didn't remove my library in IV 4 when 5 came out just added it to my machine.
    Paul
    HI Paul!!
    Jeff Knight's Avatar
    Jeff Knight Guest
    Peter,
    Are you looking for a solution that runs on a handheld device so you can collect the data as you are walking around doing your inspection ?
    Jun 2010
    Las Vegas, NV
    Quote Originally Posted by Jeff Knight View Post
    Peter,
    I typically carry a tablet computer and print onsite, but eventually want to go to a PDA type product. I would like a new piece of software.
