    Default Unducted toe-kick register
    Saw this question asked on another forum, and seems like something I ought to know:
    Is continuous ducting required to a residential toe-kick register, or can you just duct to the cabinet base area below the cabinet floor and above the sub-floor or finished floor?
    Stacy, MN
    Default Re: Unducted toe-kick register
    The cabinet does not meet the requirements for duct material and therefore can not be a duct. The duct must be run to the register.
    C.Johnson's Avatar
    C.Johnson Guest
    Tough I am not sure it is required, it seems most professionals prefer to use a toe kick extension for under cabinets
    My concern would be that if the forced air was not directed properly that it would be wasteful and the cabinet would get pretty hot inside of it, causing potential damage to items inside; i.e lady's makeup in bathroom...
    Quote Originally Posted by Fred Weck View Post
    That was my assumption as well, but is there a code commentary or other explict source of support for this opinion?
    Ooops.... I see we already did this one, I just did not use the right search terms:
    http://www.inspectionnews.net/home_i...ting-work.html
    Rick Hill's Avatar
    Rick Hill Guest
    It is very common to not run metal all the way to register. It is not code to do it that way though. A building cavity may be used for return air but supply needs to be an approved material (Not a cabinet). Section 602 and 603 in the IMC cover this subject in more detail.
    Colorado Springs, CO
    The repair to install the duct under the cabinet is relatively simple. Below are photos of a retrofit in progress.
    Bruce Breedlove
    www.avaloninspection.com
    Bob Cote's Avatar
    Bob Cote Guest
    Hi, I am know this is about forcedhot air systems but I am getting ready to install a toe kick heater with forced hot water. Would anyone have any advice on the do's and don't's on this? Thanks for your assistance
    Bob
    Bob ...
    - properly size the unit
    - provide proper electrical and water connections for the unit
    - depending on the location of the unit along the run and pipe layout, consider installing a separate zone pump for the unit. Isn't totally necessary but does help depending on pipe configuration
    - cut the back end of the cabinet out at toe kick height so the cabinet can be slid outward without worrying about the countertop
    - or consider cutting out and re-installing the bottom of the cabinet floor so that it acts as a removable panel
    These are great little units that work really well when properly installed. I used to install lots of them during kitchen remodels. Oddly I just saw some today at the supply house on closeout for $150
    Good luck
    David Bell's Avatar
    David Bell Guest
    Quote Originally Posted by Bob Cote View Post
    Bob
    The fans on these units are normally activated by an aqua-stat. Set it up for around 125 degree on and a 110 to 100 degree off.
