Thread: chimney
    beth phillips's Avatar
    beth phillips Guest
    Default chimney
    how much space should be between wooden strips & chimney (in attic)
    Default Re: chimney
    2 inches I believe.
    Default Re: chimney
    It depends.Lined or unlined masonry chimney - distance from flue; Premanufactured chimney; manufactured air cooled chimney system,. Insulated manufactured chimney system, general requirements and individual manufacturer systems' requirements vary, listed or unlisted. Type of fuel/chimney needs to be clarified as well as size.
    Default Re: chimney
    What type of chimney do you have Beth (masonry, metal)?
