    Healdsburg, CA
    Default Uncle Buck's Clothes Closet
    My - my - my, Uncle Buck provides us with a thousand laughs.
    Jerry McCarthy
    Chico,Ca
    Default Re: Uncle Buck's Clothes Closet
    The joys of funky wiring, that panel looks like it may be a XO (Either SQ D or C-H) so it does predate the prohibition being in a closet, but since it lacks a front, it would need to be relocated & would be a good time to remove the non-compliant/unsafe closet light too.
    How likely is this to be repaired/made safe? Panels being left open always spooks me.
    Nov 2010
    New Westminster BC
    It could be interesting if a tangle of wire coat hangers falls off the rail into the panel.
    Bert de Haan's Avatar
    Bert de Haan Guest
    It likely is a clothes drying kiln.
    Chuck Swan's Avatar
    Chuck Swan Guest
    Kind of reminds me of one I saw last fall. If the bath wasn't enough to get you awake in the morning a good jolt may have been in order.
    Holladay, UT
    Chuck, It's so you can wash the breakers and keep them clean. Just give em a spray with the shower wand.
    http://acloserlookslc.com/
