    steve mcgown's Avatar
    steve mcgown Guest
    Default exterior wall movement
    Can anyone please give me an opinion on what causes an exterior (brick veneer) wall to show movement towards the top of wall (when pushed). Is it foundation issues? Brick tie failure? mortar joint failure? How would you report this?
    Thanks in advanvce
    Steve
    Default Re: exterior wall movement
    The pic is too small to really see anything. Can you post an enlarged version?
    steve mcgown Guest
    here is a larger pic.
    Sep 2009
    Rolla, MO
    Steve
    Most brick veneer walls on residential structures are basically a free standing wall. If built with the typical 1-inch gap between the brick and the wall behind the center of a long wall at the top will be the easiest point to push. If the house has brick on all four sides the the closer you get to the end the less likely you will be able to push the wall because the side wall provides support. Brick ties are there to prevent the brick from pulling away from the wall, they provide little resistance against pushing.
    Randy Mayo, P.E.
    http://www.rlmengineers.com
    Succasunna NJ
    The company I used to work for always speced these ties out (305 & 315).
    They do 'help' prevent vertical movement.
    after working with these ties, it's my opinion the corrugated ties are really worthless (just MY opinion).
    Wall Ties & Anchors -- Hohmann & Barnard, Inc. - Building Product Manufacturer in Sweets Network
