Results 1 to 13 of 13
    so so, California
    Default Return air too close?
    Return air looks somewhat close. Thinking it may redirect draft.
    Mike Inspector's Avatar
    Mike Inspector Guest
    Default Re: Return air too close?
    Yeah it is too close. I see that about 4-5 times a year. Kinda makes you wonder about the AHJ during construction and time for finals, COA's.
    Mike
    The rule is return air vents should be located no less than 10 feet from an open combustion source. That looks less than 10 feet.
    Personally, I'd ignore it.
    Please explain, why you would ignore it??
    Quote Originally Posted by Marc Mazza View Post
    I know you are a smart man mark but did you actually look into the "return air vent". Where it is placed is extremely unusual in the corner of the living room. I was thinking it was more like what we call a bath trap as in a hole cut out for termite treatment behind a tub or shower.
    Just curious.
    James Duffin's Avatar
    James Duffin Guest
    I'd be more concerned about the distance of the mantel from the top of the firebox.
    Just curious.
    Ted,
    I had the same thought.
    Rick
    so so, California
    c'mon you guys...jeesh. Actually, the garage was on the other side and the FAU was installed there.
    JD...got it..its what caught my eye and led me to the return vent.
    You sure it wasn't just a make up air vent opening up into the garage?
    so so, California
    Judging by the number of holes in the thing...yes, it was.
    Don Halligan's Avatar
    Don Halligan Guest
    Hi Guys,
    I am new to this group so don't be too hard on me! If this is a return air intake couldn't the problem be easily fixed by making it a high sidewall return?
