Fire Hazard - and smoothtops may not be off (hot- ouch!).
October 21, 2010
CPSC Release # 11-016
Direct clickable link to full release: Frigidaire and Electrolux ICON Electric Smoothtop Cooktops and Slide-In Ranges Recalled Due to Fire Hazard
"Name of Product:
Frigidaire and Electrolux ICON Smoothtop Electric Cooktops and Frigidaire Slide-in Ranges with rotary knobs and digital displays
Units: About 122,000
Hazard: Liquids can pool under the control knob and cause the surface heating element to turn on unexpectedly, heat to temperatures other than expected and then not turn off, posing a risk of fire and burn hazards to consumers.
Incidents/Injuries: Electrolux has received 70 reports of incidents, including three reports of fires that resulted in property damage. Three minor burn injuries were reported.
Description: This recall involves Frigidaire and Electrolux ICON smoothtop electric cooktops and Frigidaire slide-in ranges with rotary knobs and digital displays. Model and serial numbers for the slide-in ranges can be found inside the oven door on the left side of the unit or on the underside surface on cooktop models."
See actual release for serial number range and model numbers affected.
Note some of these were being sold a month before the release date:
"Sold at: Mass merchandise and independent retail stores from January 2005 through August 2010 for between $500 and $2,500."
