    Jul 2010
    Tennessee
    Default Electrical panel connections
    I did an inspection yesterday to a foreclosure remodel. There are two issues with the installation of the new 200 amp panel board I would like some input on.
    1. The feed is aluminum however no Anti-oxidant compound was used. Are there situations where not needed?
    2. The right side main lug was bent down about 30 degrees -- I assume to make the connection easier. Can thes be bent without compromising the buss?
    Default Re: Electrical panel connections
    Re the anti-oxidant issue, see here:
    http://www.inspectionnews.net/home_i...t-coating.html
    The bent lug definitely sounds like a no-no, but a picture would be nice.
    Jul 2010
    Tennessee
    Here is a photo
    Jul 2010
    Tennessee
    And another, not so close.
    I would definitely flag that bent lug as damaged and/or inappropriately modified.
    "Amateur handiwork, there may be hidden defects, have a qualified electrician inspect and repair as needed"
    That bend is bad news. It places the lug where it could contact the deadfront/panel cover.
    A professional would have likely used anti-ox, but also would have
    Stripped the jackets back on the branch circuit wiring better than that
    Sealed the service conduit with grey putty
    Routed the branch circuits so they are not in direct contact with the service conductors
    I would tug on the cable feeding the lug and if it was in a bind I might write it up but if it was not in a bind I would not. But that's just me...YOMV.
    Jul 2010
    Tennessee
    Thank you all -- very helpful
    George Wells's Avatar
    George Wells Guest
    Quote Originally Posted by Don Horn View Post
    Everything about the picture screams "Amateur!". The area should be taped off with yellow CAUTION tape.
    George Wells Guest
    A few things
