    Default Pushmatic Spilt Buss?
    Am I looking at a split-buss panel here?
    Can't read the labeling, and I'm not familiar with the panel...
    Southwest US
    Default Re: Pushmatic Spilt Buss?
    No, this is a spilt buss
    Anyone?
    Jun 2010
    West Chester PA
    Split Main Panel.
    Last edited by Joseph Hagarty; 03-16-2011 at 04:03 AM. Reason: reviewed with enlarged photos
    Jun 2010
    West Chester PA
    Upon further review... (enlarged 1st & 2nd photo)
    Panel is a Split Main Panel.
    Thanks!
    Just to be sure I have this correct:
    1) Configuration is as shown on this section of the panel labeling (attached below).
    2) The beakers above the the "MAIN" breaker are always energized.
    3) The breakers below the MAIN are set up as "lighting section", and are controlled by the MAIN breaker.
    4) Six throws to disconnect.
    Jun 2010
    West Chester PA
    Correct..
    Ron Bibler's Avatar
    Ron Bibler Guest
    This is a pushmatic I found a few years back. The only one I have every found.
    Hope this helps
    Thanks again to you both.
