    Default Any ideas what type of insulation this is?
    I came across this white fluffy insulation in an attic and was wondering if anyone knew what it is.
    Default Re: Any ideas what type of insulation this is?
    Looks like cellulose.
    Looks like blown in fiberglass to me.
    I like the double top plate cut completely in two for those PVC pipes (condensate drains?).
    Jun 2010
    West Chester PA
    If an older home, RockWool.
    Quote Originally Posted by Joseph Hagarty View Post
    Unless it is an older home with newer insulation.
    Also, all the rockwool I've seen has been darker, grayish-blackish in color.
    I agree.
    Dom
    That definitely looks like the blow in stuff I see in suburban new construction
    Newer blown in fiberglass.
    Fiberglass.
    They are now making it fluffy, but it's still fibrous glass. Not cellulose, which is shredded organic, wood or paper based, and certainly not rockwool.
    Baton Rouge, La.
    Definitely blown Fiberglass! I believe made by Certainteed called Insulsafe. Good stuff and doesn't make you itch like the pink or yellow fiberglass.
    James Bohac
