    Iron Mountain, MI
    Default BTU Rating of a 30-gallon Water Heater
    Hi:
    Does anyon know the typical BTU input rating of a basic 30-gallon gas fired water heater?
    Thanks,
    Joe
    Default Re: BTU Rating of a 30-gallon Water Heater
    If you gave us a brand name we could look it up.
    Disclaimer: I am not a plumber, not even a scientist.
    Iron Mountain, MI
    Hi:
    The water heater in question is a Bradford-White gas fired water heater.
    23 years old.
    Pleasant Hill, Iowa
    31,000 btu's
    I think ???
    Dan Hagman ACI
    ProSite Home Inspections
    Des Moines, Iowa
    31,000 sounds close to me.
    Gerald Benson's Avatar
    Gerald Benson Guest
    The IFGC Table 402.2 says to figure 35,000 for approximate gas input for a 30-40 gallon water heater.
    Question Re: BTU Rating of a 30-gallon Water Heater
    Why would you need to know the BTU input on a 23 y/o DHW heater? It should be replaced and that would mean probably moving up to a 40/40. Are you checking on liner sizing, gas piping, or makeup air calculations?
    Mar 2010
    Madison, WI
    Here is a label from a 30gal Natural Gas I found last week.
