Results 1 to 2 of 2
    Roger Shafer's Avatar
    Roger Shafer Guest
    Default Cooktop, flexline, pan storage
    I read something about storing pans in the cabinet with the flex line exposed. What would be the correct responce to put in my reprot? What would be the correct fix in this case?
    Atlanta, Georgia
    Default Re: Cooktop, flexline, pan storage
    Quote Originally Posted by Roger Shafer View Post
    I use similar wording as electrical wiring, protect from physical damage. Remind them about how thin the walls of the pipe, etc.
    Black metal pipe is pretty durable. Replace the flex connector with rigid would be one approach.
