    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Light switch next to shower
    House built in 81, single family home. Is the location of this switch acceptable.
    Default Re: Light switch next to shower
    yes
    chris mcintyre's Avatar
    chris mcintyre Guest
    Previously posted by someone here.
    It is outside of the tub or shower SPACE, and as pictured is on the other side of protection from shower spray (curtain, enclosure, partition) it is fine in that regard.
    Is the switch mounted in a properly mounted, secured and supported vox, assume so. Hopefully the switch is not operating a fan.
    The tub or shower ZONE is for luminiares, different code section entirely.
    I assume this is not a manufactured home.
    Question Mat:
    Photo is rather cropped, something appears to the left - is the shower footprint stall/opening/approach complying as to size minimums and clearances minimums for a shower stall, from the UPC applicable to your jurisdiction at the time?
    HG yeah it was a decent size pan. What was the min size in 81, same at today?
    Funny thing is that has never been allowed in Canada, light switch, fan switch, whatever, must be 39 " (1 meter) away from the edge of the shower or tub.
    The CEC is more lenient than the NEC on kitchen receptacles and AFCI rules, but has never in the last 30 years or more, allowed a switch beside the tub. That goes for the bathroom receptacle as well. It is pretty common in the real small bathrooms for the switches to be outside the door.
    People were smaller in those days. I know I was. I think it was 30".
    HG, Hopefully the switch is not operating a fan.
    What do you see as the problem if the switch did operate the fan? It would still be allowed in the same location.
