Results 1 to 2 of 2
    Dec 2010
    New Mexico
    Default Gas supply lines for gas log fireplace
    Just ran into this yesterday. Heat-n-glo gas log unit installed in the corner of a basement.
    Two flex lines joined together from steel gas pipe are supplying the unit. Wasn't sure how to call or phrase this defect. Any suggestions?
    Default Re: Gas supply lines for gas log fireplace
    IRC G2422.1.2.1 (411.1.3.1) Maximum length. Connectors shall have an overall length not to exceed 3 feet (914 mm), except for range and domestic clothes dryer connectors, which shall not exceed 6 feet (1829 mm) in overall length. Measurement shall be made along the centerline of the connector. Only one connector shall be used for each appliance.
