Results 1 to 20 of 20
Thread: 2 10 rule
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default 2 10 rule
    Wouldn't this violate the 2 10 rule. Sorry dont have a better pic, but the flue is inside here. Home owner said, "sometimes the fire backdrafts when it is stormy.
    Thomas Jones's Avatar
    Thomas Jones Guest
    Default Re: 2 10 rule
    Interesting pic, I cant recall seeing anything like it, but I believe you're right. "Top of chimney must be at least 2' higher than anything within 10' of it, including ridge, dormers, parapets, etc. Chimneys not constructed to those standards may experience back-draft problems." I believe that custom chimney job fits here. Looks like it would do a great job of keeping the vermin out.
    Sep 2008
    so so, California
    Wow....
    But those are Good pictures! I like #3, kind of surreal.
    Are those solar panels on the roofs?
    Roofs or rooves?
    Yes, the person that designed that chimney should be ordered to remove that monstrosity stone by faux stone. The builder/mason can get up there and help him.
    Ridgewood, NJ
    Looks like a green tarp to me. Actually, metal roofing.
    Yeah, I like the pic of the mountains looking right through the chimney.
    For me the biggest concern is all that water vapor from the vent is going to wreak havoc on the chase's wood work. Even if the vent can draft properly the wood is doomed.
    Its a wood burnin fireplace with a gas log
    THe roof is copper. These places are a mess and they are almost a grand per foot
    Exclamation extreme danger
    Looks like a combustible chase/ shroud extended over and around the listed chimney termination. Since this shroud is not listed, it is illegal. This is a HUGE fire and CO hazard!!! This must be torn off and rebuilt per the listed instructions of the fireplace. The gas logs vs. wood is immaterial.
    More job security for Dale Feb....
    I like how the driveway slopes towards the garage also...Great planning there.
    Sep 2008
    so so, California
    Default Re: extreme danger
    Agreed.
    Bob,
    Agreed. Here is what has happened. The builder installed gas logs in all of these and I have seen this shroud in this community before so I have been calling it out. As time has passed people are removing the gas log and burning wood. Now the house is filling up with smoke, where as before no one noticed the back draft with the gas logs, but when the house fills up with smoke it is pretty obvious
    Exclamation Re: 2 10 rule
    Matthew, this is so bad maybe you should contact the Fire Marshal's office before someone dies either from CO or fire. Its that bad.
    That is terrible. Def point it out.
    I also noticed that the stone looks terrible. You can see the lath around the vent.
    Oh it's been pointed out, several times. They have had problems with it, they know about the backdrafting.
    Jun 2010
    San Luis Obispo
    Yes, This.
    That is one of the worst shroud / chase covers I have ever seen. The fact that anyone in the chain of builders / approvals thought that it was ok to install that.....
    For me the biggest issue is that these houses (the ones like the thumbs) may burn to the ground because of this.
    Also for the record it's the " 3' 2' and 10' rule" 3'' above AND 2' above anything above within 10'
    My 2c
    South-West Michigan
    Absolutely, and I second the comment about contacting local officials to have this corrected. Then, at least, you have done the right thing. It would not hurt to advise the current occupant not to use the fireplace, as it is unsafe.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    May 2010
    St. George, UT
    Bob,
    I'll bet the Gas supplier would help in getting this corrected. They get a bad rap every time someone croaks from CO. They will probably come out and do their own inspections, give the customers a warning, and will probably even turn off the service if they don't correct the problems.
    Phil Brody's Avatar
    Phil Brody Guest
    Well it might have gotten by for a gas fireplace but wood burning is a different animal. Can't I just put a boat hitch on my Honda Accord and pull a 40' Sea Ray ?
    May 2010
    St. George, UT
    Quote Originally Posted by Phil Brody View Post
    Yes! "Yes We can"--BO
