04-18-2011, 06:41 AM #1
Air gap in chimney exterior wall ?
Hi all,
My first post in IN. I came across this air gap in a chimney face, just under the chimney cap. Gap was clean and rectangular; looked like it was built this way. There is a flue/liner in the chimney for exhausting the gas water heater.
Can I assume that this air gap is normal and used for some form of chimney venting ?
Thanks / Dave
04-18-2011, 08:00 AM #2
Re: Air gap in chimney exterior wall ?
I have not seen anything like that ever in a masonry chimney. So I would say it is not normal.
04-18-2011, 10:07 AM #3
If I'm looking at what I think I am, it should not be there. That's enough reason to have it checked out to be sure.
04-18-2011, 10:19 AM #4
Raymond / Eric,
Thanks for your reply. I had already reported "further investigation required".....just wanted to be sure that I was on the right track.
Photo is taken looking up under the chimney cap...does seem odd that the gap is so uniform.
Dave
