04-18-2011, 07:42 PM #1
Worn out 2-wire duplex receptacles
Can any member direct to a site where they speak about worn female
receptacle that can no longer hold tight the male plug.
I need facts, to show a customer. Thanks.
04-18-2011, 08:47 PM #2
04-19-2011, 05:00 AM #3
Re: Worn out 2-wire duplex receptacles
Robert, you could just point out that loose connections cause heat to build up and create a hazard.
04-19-2011, 05:51 AM #4
Hello Robert,
That is addressed in NFPA 73. I don't have my copy in front of me right now but will post it later.
Sincerely,
Corey
04-19-2011, 06:43 AM #5
http://communities.leviton.com/servl...ec%20RTT99.pdf
you'll have to read down for dwelling info
NFPA 73, 1996 Edition
Chapter 2 Section 2-10.7 General Requirements
Receptacle contacts shall have acceptable blade retention when tested with a listed retention tester.
04-20-2011, 01:02 PM #6
04-20-2011, 04:08 PM #7
Hi Dana,
The NFPA is an organization and has not adopted anywhere.
Various NFPA codes and standards that they publish are adopted. I'm not sure I follow what you are saying.
The OP said nothing about code compliance. The OP asked for a reference and I provided one. Are you saying that you don't consider the NFPA a credible source (regardless of a particular document being adopted locally)?
The OP said nothing about this being a code battle.
Sincerely,
Corey
