Thread: Mess
    Default Mess
    Shortly after realizing that the house of my afternoon inspection today had a crawlspace (very cramped and dirty), I discovered I had no jumpsuit or knee pads in the car (where they are I don't know). In any event, this crawlspace was a disaster: heavy heavy heavy fungal growth, extensive dry rot from water damage on ends of joists, sill plates, and rim joists, compression on bottom of center beam bearing on top of brick turned on it's side, rotting and inadequate framing for the whilrpool tub and the modified floor framing. Enjoy.
    Default Re: Mess
    More.
    Default Re: Mess
    Did I mention there was a Porsche in the garage?
    Jason Welch's Avatar
    Jason Welch Guest
    Default Re: Mess
    Good thing you still went in there even though you had no protective gear..
    Tim Moreira's Avatar
    Tim Moreira Guest
    Default Re: Mess
    The Porsche looks to be kept in the same shape
    william siegel's Avatar
    william siegel Guest
    Default Re: Mess
    Kudos to you Nick. I know a lot of inspectors who would not have gone under that and made up some (lame) excuse.
    Also looks llike subterranean termites on one of those first pics.
    Tim Moreira Guest
    Default Re: Mess
    Well.....
    I'd say that there is a moisture issue in there.
    Ya think?
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Mess
    I'm a big dumb-azz too, Nick. If I forget my bag of crawl-goodies, I'll still take the plunge like a fool-- yeah even without a respirator .
    If anything in this job is a learning experience, forgetting or not bringing the crawl-gear is a crash-course in inspecting 101. I now carry some disposable crawl coveralls (ShueBee) under the back seat of the truck for back-up.
    The very worse thing any of us can do is to go splunkering under homes without the right protective equipment, i.e.; breathing apparatus, pads, clothing, pads, etc... Some of these old home have previously been treated with some pretty nasty pesticides (Chloridane comes to mind).
    I feel your pain. Been there done that!
    I just hope you had your respirator with you...
    Rich
    Martin lehman's Avatar
    Martin lehman Guest
    Default Re: Mess
    Nick, what was your recommendation to the buyers???
    Default Re: Mess
    Run away and don't look back. I didn't use those exact words but I didn't mince words either. I told them it was a mess and give them the option to end the inspection right then and there. I offered to knock $100 off the fee as I hadn't gotten into the rest of the house yet. They discussed it and opted to forge ahead with the rest of the inspection. They were probaly looking at $20,000+ in repairs just in the crawlspace.
