    Default CSST through wall
    I came across a CSST line run through a chimney. The installer wrapped the pipe with some electrical tape before filling the hole with cement around it. Is this an acceptable "cushion"? Thanks in advance.
    David Bell's Avatar
    David Bell Guest
    Default Re: CSST through wall
    Should be sleeved and correctly fire stopped
    Ray Norton's Avatar
    Ray Norton Guest
    I go directly to the manufacturer when I see suspect installlations such as this one. See Sections 4.3.8 and 4.3.9 for installation requirements (link below). In short: No, eletrical tape is not an adequate alternative to a compliant sleeve. Also, the CSST may not be routed through a chimney chase, IRC G2415.1 prohibits this.
    http://www.gastite.com/include/langu..._D+I_Guide.pdf
    I hope this helps. I have been hesitant about joining in because sometimes legitimate posts, good questions and good answers get beat up beyond recognition. (Fingers crossed)
