    Erwin, TN
    Default Return air in bathroom
    1st time in ever seeing the return air for the entire house located in the bathroom. Is this acceptable by code??? Thank You
    Default Re: Return air in bathroom
    Not acceptable, no. In the 2006 IRC it's M1602.2 Prohibited Sources.
    No returns allowed in bathrooms.
    Mar 2009
    Charlottesville, Va.
    I'm curious...is there reasoning behind that other than the obvious...room too small, frequently closed, moisture, proximity to exhaust fan/duct, introduction of flatulence into the public rooms.... ?
    Jun 2008
    Stacy, MN
    Hairspray and other aerosols can damage the heat exchanger in the furnace is what I was taught.
    Don Burbach's Avatar
    Don Burbach Guest
    Quote Originally Posted by Fred Weck View Post
    I think its the 'other aerosols'!
    Utah
    Talking Re: Return air in bathroom
    Quote Originally Posted by Don Burbach View Post
    Exactly!
    It would appear to be common scents.
