Results 1 to 13 of 13
    Tony Vargas's Avatar
    Tony Vargas Guest
    Default Pipe on slab foundation
    Just curious how do some of you inspectors write these up . This was
    a pipe on outside exterrior and there was some excavation but really
    no problems other than that looks of it and water intrusions . see pic
    Default Re: Pipe on slab foundation
    Quote Originally Posted by Tony Vargas View Post
    What is the pipe for?
    If I found something like that and I had no idea what it was for or did I would take a picture of it and tell my client in the report that I found a pipe at X location and I have no idea what it is for or does.
    Keep it simple and report what you see.
    Tony Vargas Guest
    Scott
    This house was only 8 yrs old and the pipe was about 6inch round and
    metal like cast iron or something i just took a picture and kept it simple like you said not throwing up red flags . i could not verify what this pipe was .
    thanks for your advice
    Joe Razzo's Avatar
    Joe Razzo Guest
    Hmm..interesting
    Can it be possible that there was an underground oil tank underneath, before the house was built? This looks a lot like an oil tank's vent pipe
    Good discovery though!
    Scott
    This house was only 8 yrs old and the pipe was about 6inch roundand
    Sorry to question this, but looking at the flora in the picture I'm having a hard time seeing this to be anything near six inches in diameter. Perhaps you meant its elevation from the ground was nearer to six inches?
    What's that yellow cord or cable behind the yucca or aloe leaf to the left apparently entering/leaving the building above the slab? Perhaps that may yield a "clue" as to the former function.
    Picture is somewhat blurry, but it looks like it could be rigid metalic conduit. Might also be galv gas pipe. Although you described it to be somewhat like cast iron, doesn't look that way in the picture, however if one was unfamiliar with "black gas pipe" or black steel gas pipe, aka black "iron" gas pipe, one might describe it as looking similar to cast iron.
    Perhaps a bollard or post light was once present, gas or electric, a gas grill, even an outlet (receptacle) or other box ped. Is that nipple end threaded? Is that nut brass or bronze? Is that a wire inside, debris, a bug, or a photo affect? Thinking that yellow cord or cable to the left might be related.
    Tony Vargas Guest
    ok around 4inch in diameter i have no idea what it is can only see so much and was able to touch it and felt like cast iron, thanks alot guys for your input much appreciated.
    Anthony Hubbert's Avatar
    Anthony Hubbert Guest
    To me, my first take is a busted sprinkler head. Look at the height, look like its palstic from the picture, its in corner of a flower bed or next to a wall.
    First thing that comes to mind when I see pipes is
    Is it use as a vent? If use as a vent to what equipment? (tank, furnace, sewer line)
    Next questions is, is it used a drain pipe for some type of drainage?
    Next question is, is it used to supply water? If so, from what?
    I recommend looking at other house in the area, for the same exact item
    Terry Griffin's Avatar
    Terry Griffin Guest
    I think Scott has the best reply. If you don't know something take a picture, say so and move on. I may recommend that if the home buyer had a huge question about it call a plumber.
    Tony Vargas, please don't pull my leg.
    You see the yellow rope, cord or cable to the left...
    You see the plants (flora)?
    That's some trick photography if we're supposed to believe this "pipe" is four inches in diameter (let alone six inches D)!
    Not picking up what you're putting down.
    Sprinkler head.
    Jul 2010
    Burbank, CA
    Looks like a sprinkler head to me. If that's structural foundation behind it, looks like it might be failing. Much bigger problems than a mystery pipe.
    so so, California
    Is that / are those segmental blocks or the foundation? (around the pipe)
    Houston, Texas
    There seems to be some confusion about which pipe in the photo is the subject of discussion. I think the original poster is asking about the large pipe visible in the hollow of the slab behind the sprinkler head.
